Activity › Forums › Apple Final Cut Pro Legacy › Putting HDV back to tape
Posted by Ross Marshall on July 8, 2008 at 11:24 amUsing Final Cut 6 Edited a HDV production that was shot on a Z1. Trying to put it back to tape but Final Cut cant seem to find the device. Messed about with all the settings but its just not happening, any advice.
Thanks in advance Ross
David Lee replied 18 years, 2 months ago 4 Members · 3 Replies -
Jerry Hofmann
July 8, 2008 at 2:53 pmHave you tried trashing preferences, then using the HDV easy setup that matches your source material’s properties?
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Jerry Alto
July 8, 2008 at 4:47 pmRoss- Does your computer see the camera; apple menu>about this Mac>more info>firewire? Many times you have to quit out of FCP then relaunch (along with Jerry’s suggestions). Also remove any other firewire devices that are on the same bus.
HTH,
Jerry‘Change is inevitable. Struggle is optional’
G5 Dual 3GB Ram
FCP Studio 6.02
External 1 TB SATA Raid 0
Kona LH, Second system w AJA ioLA
Sony Z-1
GV-HD700 -
David Lee
July 9, 2008 at 7:34 amYou can record back to Sony HDV camcorders. I do this often with the A1 and Z1 using firewire.
You must use PRINT TO VIDEO to do so.
First, make sure you captured in HDV (either 1080i50 or 1080i60).
You can only lay back in the format you captured (based on camera).Under AUDIO/VIDEO SETTINGS:
1. Make sure the correct SEQUENCE PRESET is set to either 1080i50 or 1080i60.
2. Capture Preset: HDV
3. Device Control Preset: SONY HDV
Then select tab: AV DEVICES
On box DIFFERENT OUTPUT to Edit to Tape/PRINT TO VIDEO
select HDV (1440×1080)60i (USA) or 60i (Europe)
audio: defaultPlace your clip on time line, go to PRINT TO TAPE follow directions.
FCP will do some voodoo to prepare for playback.
When it is ready it will tell you to start record on your machine. Start your machine, then hit OK.
You WILL see the REC going in realtime in the Z1 viewfinder.hope that helps.
smilez
d
