Activity Forums Apple Final Cut Pro Legacy Putting HD into an SD
  • Putting HD into an SD
    Posted by Kian Mckellar on May 19, 2009 at 9:00 pm
    I have a project filmed and edited in DVCPRO 1080 and I want to throw it into a NTSC sized sequence. Currently using black bars to simulate letterboxing on my 16:9 project. Is there some way I can convert my sequence into 4:3 with letterboxing. I’ve tried just changing the setting on the sequence but it ends up squishing things horribly.
    Rafael Amador replied 17 years, 3 months ago 4 Members · 3 Replies
  • John Fishback
    May 19, 2009 at 10:02 pm
    Read this thread, but do what Raphael suggests in his 2nd comment near the bottom. In your sequence settings > Render Control, make sure the quality is set to Best.
    https://forums.creativecow.net/thread/8/1036204#1036204
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Luke Dollard
    May 20, 2009 at 12:00 am
    or simply create a dv sequence import the hd into the timeline and adjust the aspect ratio to fit. or shrink to fit.
  • Rafael Amador
    May 20, 2009 at 1:29 pm
    Hi Kian,
    Just drop your HD sequence in a 4×3 NTSC time-line.
    As John points, setting “Motion Effects Rendering: BEST” should help with the downscaling.
    rafael
    http://www.nagavideo.com
