Activity › Forums › Boris FX Particle Illusion › putting fire into a boxing ring
  • putting fire into a boxing ring
    Posted by Bodybuildingbs on March 17, 2006 at 11:20 pm
    I have this video project I have a video of a boxing/wrestling ring and I would like to know how to either:
    1. Make it seem like the fire is actually IN the ring
    or
    2. Surround the ring like a cage match with a cage of fire..just front view.
    Any ideas and thank you.
    Elvis Deane replied 20 years, 6 months ago 2 Members · 1 Reply
  • Elvis Deane
    March 22, 2006 at 5:44 pm
    To make the fire look like its in the ring, you’d have to use Blockers (or a mask in your compositing program) to mask out anything in front of the ring (like the ropes and turnbuckles).
    For the cage of fire, you can right-click on your fire emitter and turn it into a line emitter, and keep adding points as you need to make lines across the cage.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
