Activity › Forums › Adobe After Effects Expressions › putting a stop to random(minValOrArray, maxValOrArray)
  • putting a stop to random(minValOrArray, maxValOrArray)
    Posted by Hymn Wong on April 14, 2008 at 3:31 am
    how can i put a stop to a random(0,359) generator,
    so that on the first frame, the value won’t change, and keep the same value?
    i am using this for changing the color of each object with “CC color Offset” on the first frame
    how about adding a “checkbox control”?
    thanks in advance!! (urgent..)
    Hymn Wong replied 18 years, 5 months ago 2 Members · 2 Replies
  • Filip Vandueren
    April 14, 2008 at 10:46 am
    this should do the trick:
    seedRandom(index,true);
    random(360);
    the first value (index) will make sure the random number is unique for every layer, the second value (true) sets the “timeless” option to true: the values will NOT be recalculated every frame, so you have 1 constant random value per layer.
  • Hymn Wong
    April 14, 2008 at 1:21 pm
    thanks Filip! it works great~! 😀
