Activity › Forums › Adobe Premiere Pro › putting a gap between each clip
Posted by Alex Dinnin on November 5, 2010 at 9:38 amI’ve got to lay off about fifty clips to tape..
Is there a quick way for me to put a second gap between each clip..
I’ve looked in the manual and couldn’t find anything.. just wondering if there was some clever short cut ??
cheers
Alex
Hamza Fletcher replied 7 years, 10 months ago 6 Members · 5 Replies -
Scott Morrison
November 5, 2010 at 1:40 pmAlex,
I have the same issue, but after researching, don’t think there is any easy solution. Basically, until PPro incorporates scripting support (if ever), then it must be done manually.
Sorry for the bad news.
Scott Morrison
Just an amateur trying to learn -
Alex Udell
November 5, 2010 at 2:07 pmmake a new black clip in the project panel and load it into the source viewer
set the duration to the size of the gap you need
select your sequence panel
1) Press Page down
2) Press , to insert edit the black slug in
repeat this start from “1)” above
should be quick….
Alex
Jonas Bendsen
January 12, 2015 at 10:43 pmYou rule. Such a simple answer, but one I’ve been looking for for quite a while!
This is especially helpful if you have a string of clips butted up against each other and decide you want to reinterpret the footage at a slower rate (like converting 29.97 to 23.976). If you simply apply this change, the clips will convert but not expand to their full length (they will be the original length, thus clipping the ends).
This is my life, I edit and edit and edit and edit…https://TeahmBeahm.com
https://Digabyte.com -
Rob Leslie jr
March 12, 2015 at 5:28 pmA small trick I use, select all the clips and change their speed and duration to be a percentage faster. Then nest them into a new clip, then change that new nested clip’s speed and duration a percentage slower (to make the first %) to get you back to normal speed.. but this time with a percentage gap between all the clips.
Not perfect, but might help.
