Activity Forums Adobe After Effects Expressions Puting an item inside a comp
  • Puting an item inside a comp
    Posted by Avinash Ramanath on April 21, 2017 at 7:13 pm
    Dear All,
    I have made a template with three compositions, namely Placeholder1, Placeholder2 and Placeholder3
    I have three items in the project panel namely Clip1.mov, Clip2.mov and Clip3.jpg
    how to move Clip1.mov inside Placeholder 1 and so on?
    also, the duration of Placeholder should auto match duration of Clip
    Please help it’s a bit urgent
    Steve Sierra replied 9 years, 4 months ago 2 Members · 1 Reply
  • Steve Sierra
    April 22, 2017 at 6:35 am
    Hello,
    I’m new to scripting, but this is what I’d do :
    -You could create solids in your placeholder comps and then use “replaceSource()” to replace them with your clips.
    -To get the clips numbers to match with the placeholders numbers, I’d use slice on the names, but if you have more than 9 clips, you have to name them Clip01, Clip02,Clip03, etc…
    – I still haven’t messed around with comp settings, but you can get Item’s duration using “app.project.item.duration” I think. It’s a read/write for comps and a read only for other Items.
    I hope this can help.
    Cheers !
