Activity Forums Adobe After Effects put pictures into a globe
  • put pictures into a globe
    Posted by Cjahrens87 on July 13, 2006 at 8:04 pm
    I want to take pictures and put them on the surface of a globe and have it spin. Is there a simple way of doing this in AE. I have limited knowledge of AE so detailed explanation or a link to a similiar tutorial would help.
    cja
    Steve Roberts replied 20 years, 1 month ago 2 Members · 1 Reply
  • Steve Roberts
    July 13, 2006 at 8:18 pm
    1. Make a composition that is twice as wide as it is tall. Try making the height twice the height of your finished video. Name this something like “map comp”.
    2. Arrange all your photos within this comp. You might want to just do a few photos for a test, then go back and change the size of this comp if necessary.
    3. Make a new comp that is the size of your finished video. Name it “main” or something.
    4. Drag the “map comp” into the “main” comp.
    5. Apply effect>perspective>CC sphere to the “map comp” layer.
    6. Tweak the settings for the effect, maybe animate its rotation with keyframes.
