Activity Forums AJA Video Systems PURGING CACHE…
  • PURGING CACHE…
    Posted by Kevin Gardam on October 25, 2005 at 5:18 pm
    Sometimes when laying back to tape I find it best to shut down and count to 10 and then fire up again, so as to avoid dropped frames on playback to tape. Now in after effects you can purge the cache and avoid having to restart….is there anyway you can do the same in fcp to remove a corrupted cache.?
    Thanks in advance.
    Kevin Gardam replied 20 years, 11 months ago 4 Members · 13 Replies
  • 13 Replies
  • David Battistella
    October 25, 2005 at 6:15 pm
    What is the system config?
    I find this is almost always due to not enough RAM or never shutting down the machiine.
    David
  • Kevin Gardam
    October 26, 2005 at 7:44 am
    I have a dual 2 with 3.5Gb of ram, and I get corrupted caches fairly regularly
    even though the machine is shutdown every night.
    Any thoughts..can you purge the cache in FCP or even from the desktop.
    Thanks in advance
  • David Battistella
    October 26, 2005 at 11:58 am
    You can trash preferences OR you can delete the POA cache directly from the root level of the hard disk.
    That might do it.
    David
  • Gary Adcock
    October 26, 2005 at 2:23 pm
    [David Battistella] “You can trash preferences OR you can delete the POA cache directly from the root level of the hard disk. “
    Try FCP rescue
    https://www.apple.com/downloads/macosx/video/fcprescue.html
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
  • Kevin Gardam
    October 27, 2005 at 7:14 am
    Thanks Gary/David,
    Isn’t trashing preferences alittle extreme. A shutdown is normally sufficient.
    I’m just trying to avoid a fairly lengthy process to bring the machine back up.
    What is the POA cache exactly and do you feel it could be a preference issue.
    I’ve downloaded Rescue but not put it to use yet.
    Thanks again.
  • Gary Adcock
    October 27, 2005 at 2:40 pm
    [Kevin Gardam] “Isn’t trashing preferences alittle extreme. A shutdown is normally sufficient.”
    prefs are only the setting for your Application, they are rebuilt to the default when the application launches.
    restarting the machine will not fix a problem with a corrupt cache file, neither will restarting the app.
    FCP Rescue allows you to do this and then restore a previous version of your settings. so nothing is lost.
    how do you see this as extreme? more extreme than having to completely rebuild a corrupt project from scratch?
    Gary Adcock
    Studio37
    Chicago, IL USA
  • Kevin Gardam
    October 27, 2005 at 3:26 pm
    OK Gary , why don’t I have dropped frames after I have shutdown and fired up again. I do not restart, I do a proper shutdown. There must be a cache in use somewhere.
    Also David mentioned the POA cache. What is it and where is it.
    I’m simply curious
  • Gary Adcock
    October 27, 2005 at 4:22 pm
    [Kevin Gardam] “Also David mentioned the POA cache. What is it and where is it.”
    search for POA in spotlight ( 10.4.x)
    or use the find function in the OS.
    Gary Adcock
    Studio37
    Chicago, IL USA
  • Kevin Gardam
    October 27, 2005 at 4:30 pm
    Sorry Gary, I’m not that daft, I’m in 10.3.9 and my search engine can’t find it.
    What is the POA Cache anyway.
  • David Battistella
    October 27, 2005 at 5:03 pm
    Read about how to do this as well.
    THe POA cache and MOA cache are caches created by FCP. The POA can be deleted and is recreated teh next time you start FCP. Of course it will be a fresh cache once you ahve deleted and restart. Sometimes it is at the root of some FCP cache issues.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    David
