Activity › Forums › Apple Final Cut Pro Legacy › Purchasing Western Digital My Book
Posted by Cory Mckechnie on January 21, 2008 at 2:35 amAnyone know of anywhere I can pick up a Western Digital My Book
Cory Mckechnie replied 18 years, 8 months ago 8 Members · 23 Replies -
Steve Eisen
January 21, 2008 at 2:43 amYou can try Goggling!
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Cory Mckechnie
January 21, 2008 at 2:48 amYes clearly, so I now remember why there’s a preview post. It seems the Cow doesn’t like when you cut and paste a TM symbol in your post … here’s the rest of my clipped question:
Anyone know of anywhere I can pick up a Western Digital My Book Pro Edition II (WDG2TP20000) External Hard Drive in Canada? The places listed at Western Digital don’t ship to Canada (interestingly, not even at http://www.westerndigital.ca itself). I’ve exhausted all my usual sources.
If not, anyone have suggestions for a 2TB external hard drive? I’m not tied to the Western Digital (although it does look really good) but what are others using for an external Firewire/USB hard drive solution?
Cory -
Walter Biscardi
January 21, 2008 at 2:49 am[Cory McKechnie] ”
Anyone know of anywhere I can pick up a Western Digital My Book”I’ve seen them in all the leading electronics stores. I purchased two at Costco.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Cory Mckechnie
January 21, 2008 at 2:54 amThanks Walter, I’ve tried Costco but they only have the old 1TB solutions right now. I will keep looking there.
BTW, I hope you have a look at the rest of my post … geez you guys are quick 🙂
Walter Biscardi
January 21, 2008 at 2:55 amLaCie has a really nice 2TB external FW unit that you can easily cut uncompressed SD and DVCPro HD / HDV with. Or use it as a backup device like we do.
Cory Mckechnie
January 21, 2008 at 3:01 amThanks Walter. I’ll have a look at the Lacie’s, maybe it won’t be as difficult to get as the WD’s.
Walter Biscardi
January 21, 2008 at 3:06 amhttps://www.directdial.com/WDG1C2500N.html
Cory Mckechnie
January 21, 2008 at 3:36 amThanks Walter, I checked there but they don’t have the 2TB WDG2TP20000 model. I did find it at CDW.ca:
https://www.cdw.ca/shop/products/default.aspx?EDC=1304642
Ben Holmes
January 21, 2008 at 10:18 amCory
I know the price is good on the WD drives, but I beg you to consider a better drive if you can – data is always more valuable than the drive you put it on (unless you own an XRaid, ho ho ho). I have had to use DiskWarrior a couple of times recently to repair WD MyBooks after near-catastrophic data losses, in both cases the b-node tree on the drives was damaged.
You get what you pay for with drives, and in my experience (and others here if you search posts for these drives) these are not reliable. The cases are cheap, the connectors not great (athough I would level the same complaints at Lacie) and the drives not as reliable as others. Is your application critical? Putting 2Tb on one of these terrifies me.
Certainly, the Lacie is better, although I no longer use them after problems – one of mine died, the other suffered from failure of the FW connections, the ports only being secured by the solder attaching them to the board. If you need a mobile drive, I can recommend G-Raid. You can see prices at http://www.g-techology.com.
There are many many posts here about Lacie and Western digital arrays here – have a search and a read (the last few months should turn up a few) before you commit to this purchase.
Ben
Editec Broadcast Editing Ltd
EVS & FCP specialists for live broadcast.
OB Server 1 HD – Mobile FCP editing done right.
https://www.editecuk.com/OBServer2.html -
Xiaolom
January 21, 2008 at 12:58 pm[Ben Holmes] “I have had to use DiskWarrior a couple of times recently to repair WD MyBooks after near-catastrophic data losses, in both cases the b-node tree on the drives was damaged.
“Interesting, I have this issue recently with my “MyBook”. So I wouldn
