Activity Forums Adobe After Effects Puppet tool value problems
  • Puppet tool value problems
    Posted by Edward Foster on April 17, 2010 at 5:15 pm
    I’m animating a character with the puppet tool using slipperyrockNYC’s animation tutorial
    https://www.slipperyrocknyc.com/SlipperyRockNYC/Animation_Tutorials/Entries/2009/3/7_Using_Parenting_and_Puppet_Tools.html
    I’ve used it before with good results, this time however I’ve run into a problem. When I place puppet tool points their values are wildly outside my comp. For instance when I try to place a point at X:932 Y:480 (by the info panel) the puppet point value becomes x:2186.105 y:478.3426
    This becomes problem when parenting nulls to the puppet points because the nulls end up being off in the middle of nowhere instead of on top of the points they’re supposed to be manipulating.
    I can’t seem to find mention of this anywhere else. If anyone has a fix it would be greatly appreciated!
    Edward Foster replied 16 years, 4 months ago 2 Members · 2 Replies
  • Bartek Skorupa
    April 18, 2010 at 12:51 am
    Pins are placed relatively to the layer. What you see in the info panel is the absolute position.
    If your layer is not placed at the center of the comp or it’s scaled – you get this behavior.
    Reset the position and scale of your layer, or if you have to have it scaled, or placed somewhere else – you’ll just have to pre-compose it.
    Bartek Skorupa
    Warszawa, Poland
  • Edward Foster
    April 18, 2010 at 2:54 am
    simple but probably something that would have never occurred to me alone.
