Activity Forums Adobe After Effects puppet tool causing unwanted transparency
  • puppet tool causing unwanted transparency
    Posted by Melissa Hill on February 10, 2009 at 8:53 pm
    I’m having a weird problem that I just can’t seem to find the answer to anywhere.
    I’m trying to use the puppet tool to do a basic but realistic motion. The layer that I am attempting to do this on is a continuously rasterized layer (vector image from AI), within its own pre-composition. Whenever I put in a pin, suddenly an area of the layer has this dotted line of transparency. It looks as if its the outline of the layer offset to a different position. When I un-click the continuous rasterization, it disappears, so this is definitely the issue, but the layer MUST be rasterized.
    Thanks for any advice,
    Melissa
    Chance Turcotte replied 13 years, 9 months ago 5 Members · 4 Replies
  • Brian Cibula
    March 17, 2009 at 10:44 pm
    I’m having the same problem, can anyone help?
  • John Hammond
    April 15, 2009 at 5:04 pm
    I had similar issues. Here’s my setup:
    make ‘cut out style’ animation by animating separate limb layer rotations, with a heirachy setup from torso down to fingers.. etc.
    Then precomp the whole character after it’s animated.
    Then add puppet tool layer of animation. I had trouble with bits of the character going transparent, but I fixed it by changing the puppets mesh expansion right up. (find it by twirling down puppet tools in timeline on your layer, twirl down mesh – find expansion.
    I know its a few months since you posted. How is progress? I just posted on the AE forum a post about using puppets with rigged characters, you may be interested or have some tips for me.
    https://forums.creativecow.net/readpost/2/954942
    John
  • Brent Griffin
    November 4, 2010 at 1:22 pm
    I’m having the same problem, trying to animate a hand walking, got the animation right then had this damn transparent outline wrecking the image. Had to abandon the animation to get the job done unfortunately.
  • Chance Turcotte
    December 12, 2012 at 1:45 am
    I thought of a neat trick tonight to solve this dotted line nuisance. This problem seems prevalant among layers with nested puppet tools. It also happens with video files to me.
    I don’t bother with splitting up layers. I just duplicate my layer and move it a few pixels in a direction. This will hide that white jagged edge nicely!
    I know this is a fast dirty method of correction but my animations are quick and cheap anyway. I have an old laptop.
    I’d like to know what really causes that tear with the puppet tools. Anyone know?
