Activity Forums Adobe After Effects puppet tool
  • puppet tool
    Posted by Lori Newman on April 19, 2009 at 5:23 pm
    I animated with the puppet tool, and now when I want to move the object
    everything gets out of wack. I tried using a null and moving it but it still changed everything, even putting it in a subcomp. There must be a simple solution for this.
    thanks
    Joe Clay replied 17 years, 4 months ago 2 Members · 1 Reply
  • Joe Clay
    April 20, 2009 at 1:49 pm
    That shouldn’t be a problem. The only time I’ve seen something like that happen, is if there’s a lot of alpha to the object and some parts may be too thin for After Effects to recognize that they are contiguous. After Effects tries to guess a mask around objects when using the puppet tool, sometimes you have to help it along by adding your own mask. If I recall correctly, this only matters when moving the pins themselves, not changing the position property.
    This only seems to happen with certain images, as I can’t recreate it right now. How are you trying to move it? You might be able to get away with a transform effect after the puppet effect.
    Having it do the same thing while precomped is definitely strange. Do you have continuous rasterization checked?
    Joe Clay
    Animator
    gra-phix.com
