Activity Forums Adobe After Effects Puppet pins not showing
  • Puppet pins not showing
    Posted by Rulof Janse van rensburg on February 27, 2019 at 9:02 am
    So I’m using the puppet pin tool for animation and all of the sudden the pins stopped showing up on one of the layers. Even when i select the pins in the layer’s properties (if that’s the right term). the other layers still show their pins
    Please help
    Tristan Summers replied 5 years, 3 months ago 3 Members · 3 Replies
  • Oleg Pirogov
    February 27, 2019 at 11:16 am
    I’ll try and guess: have you turned on Continuous Rasterization?
  • Rulof Janse van rensburg
    February 27, 2019 at 2:52 pm
    No, I’m using png images so the continuously rasterize option isnt available. But i quit and restarted After Effects and now it’s working again. But thanks for the feedback
  • Tristan Summers
    May 28, 2021 at 11:22 am
    Thanks for this, helped me. Why can’t it work on continuously rasterised?
    Maybe an opportunity to reiterate the process of operations?
    Layer sized effect can’t work if comp bleeding off edges?
  • Madaline Erazmus
    June 2, 2023 at 4:20 pm
    I know this thread is 2 years old, but if anyone is looking for a solution like I was. Try clearing your cash, restart the program, and if all else fails try this.
    1. select your layer and mesh you’re working with
    2. select the puppet pin positioning tool and tick the box that says Show. You may have to toggle it once in a while.
