Activity Forums Adobe After Effects Puppet pins adding rough scraps
  • Puppet pins adding rough scraps
    Posted by James Roberts on October 3, 2009 at 12:09 am
    Does anyone else have a problem with Photoshop graphics having little extra image scraps after using puppet pins to distort it over time? I’ve tried a couple of tests and both times there were a few spots that render along with the clip to a .mov file. I don’t mind it being there while working on the composition, but if it ends up on the render that sort of makes the puppet pins useless. Do I need to create an animated mask to clean up these scraps, or is there a preferred file type to use this way? I used PNG images in these.
    James Roberts replied 16 years, 11 months ago 2 Members · 2 Replies
  • Todd Kopriva
    October 3, 2009 at 12:53 am
    Try expanding the mesh a little bit and/or increasing the number of triangles in the mesh.
    If the number of triangles is too small, the outline may be too rough, and a little bit of the image may be clipped off and left behind.
    See “Work with Puppet pins and the distortion mesh”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • James Roberts
    October 3, 2009 at 10:51 am
    That was it. As soon as I increased the expansion number they hit the road. Thanks, Todd! I have plans to use this process for a number of things, but that would have spoiled it. Now I’m good to go.
