Activity Forums Adobe After Effects Puppet pin and position?
  • Puppet pin and position?
    Posted by Gabi Bucataru on February 14, 2014 at 8:30 pm
    Hi Gang!
    Please forgive my newbie question.
    How to you change position shape that you altered with the puppet tool? Seems like the puppet pins pin the shape to the canvas and changing the position becomes impossible.
    thanks!!!!
    Stephen Smith replied 12 years, 6 months ago 2 Members · 3 Replies
  • Stephen Smith
    February 14, 2014 at 8:48 pm
    Do you want to change the position so it animates from the last position or you don’t like where you put the position and want to change it location?
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Gabi Bucataru
    February 23, 2014 at 3:38 am
    Stephen –
    Thanks for the reply!! I wanted to to change its position after I animate it with the pins. To explain it better, I have a vertical bar with three pins top-mid-bottom.
    1. I animated the middle pin so now the bar is bent in the middle
    2. As it is now (bent) I would like to change its position.
    Now that I am thinking, precomping would solve this, right?
    thanks!!
    gabi
  • Stephen Smith
    February 26, 2014 at 10:29 pm
    If the Pins and the bar are separate layers then yes you need to precomp them together.
    Stephen Smith
