Puppet FX with Different Layers
I’ve done a bit of a dig around the forum and can’t find an answer to this exact question but please point me in the right direction if this has been already answered.
I have picture of a phonograph in After Effects and I want to animate an object being swallowed by the speaker of the phonograph. I want to use the puppet tool on the phonograph speaker to simulate a mouth swallowing the image.
I have divided the phonograph speaker into 2 images on separate layers: The front of the speaker and the back of the speaker so that the object can pass “through” or “into” the speaker and not just behind it.
So far this works ok but how do I apply the puppet FX to the speaker as a whole? I tried adding the layers to a pre-comp layer but then the object just ends up behind the speaker not “in it”.
Is there a way to lock the layers so that I can apply the puppet effect to both of them or can you think of a better way to achieve the desired effect?Thank you for any help.
