Activity Forums AJA Video Systems puple image from betcam
  • puple image from betcam
    Posted by Core Van der hoeven on October 30, 2008 at 12:21 pm
    Hello
    Probebly something simple, I’m a novice with betacam
    I’m trying to capture from a betacam deck with my AJA io HD
    I get an image, but it is very purple
    is there someone out there who can give me some advice
    Core
    Mark Beazley replied 17 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mark Beazley
    October 30, 2008 at 2:58 pm
    Make sure your component input is switched over to YUV and is set to Betacam levels (as opposed to SMPTE). Click on the component input on the control panel and it should let you change away.
    -mark
  • Core Van der hoeven
    October 30, 2008 at 3:48 pm
    thanks for your reply,
    The component input is set to component beta
    It’s the only other option I have with component
    Core
  • Jeremy Garchow
    October 30, 2008 at 4:38 pm
    Is your monitor set to RGB instead of Component?
    Jeremy
    October 30, 2008 at 4:43 pm
    no, it’s set to component
    Is there maybe a setting on the betacam deck wich could be the course
    Core
  • Bob Zelin
    October 31, 2008 at 2:04 am
    can you use these same cables to plug your Beta component signal directly into the component input of your TV monitor ? This will tell us if you have a problem with your Beta VTR or TV monitor (or cables).
    ALSO, go to the I/O HD Control Panel, click the CONTROL tab, and select TEST PATTERN, color bars –
    do you see good color bars, or do they look purple ?
    Bob Zelin
    October 31, 2008 at 8:31 am
    That’s an idea, I’ll check that right away, maybe the
    cable’s are not doing what they supposed to do
    My client monitor works ok and I have good color bars
    It’s the color bars from the tape that are purple(and
    the images)
    Core
  • Mark Beazley
    October 31, 2008 at 1:25 pm
    The Beta input might be set to RGB instead of YUV, what is the model of Beta deck you are using?
    -mark
