Activity Forums DaVinci Resolve punctuation in reel names?
  • Margus Voll
    April 28, 2011 at 6:34 pm
    Yepp.
    Just put the same characters that you need to change.
    space dot space > chances to > space
    For me it works well.
    If you need i can make screen capture of it.
    Margus
    https://iconstudios.eu
  • Larry Di stefano
    April 28, 2011 at 6:44 pm
    But that would change both instances of it in the filename which I don’t want to do. If my file is called
    “01. best shot ever (p. 1).mov” it would remove both dot-spaces and my clip wouldn’t match my edl.
    Also if there wasn’t a space and I needed to get rid of the dot wouldn’t automator also remove the dot before the extension?
  • Margus Voll
    April 29, 2011 at 11:52 am
    Yes if you have identical dots so to say.
    You could change edl afterwards if needed.
    Lets say you have 01. best shot ever .mov
    and in replace condition you put
    01. best > 01 best
    or
    . best > “space”+best
    That should do it
    just select base name only for the condition
    Should be simple
    Margus
Page 2 of 2
