Activity › Forums › Apple Final Cut Pro Legacy › pulsing image
  • Posted by Will Pigeon on December 4, 2011 at 9:50 pm
    I have limited experience with FCP so I am sorry to take up your time with this question.
    I already have one project on the go which when I preview looks fine, the image is as it should be and each clip of the movie plays through successfully.
    I have just opened a new tab to make a new edit of the same material, and when i cut and paste clips from the old to the new tab and play them back, the image pulses every few seconds. Different clips pulse to a different degree. Have just rendered all, and some of the clips are still pulsing every other second. Its only slight, but definitely doesn’t happen on the other edit…
    Please could someone help me outta this jam
    thanks
    kP
    Will Pigeon replied 14 years, 10 months ago 2 Members · 2 Replies
  • Fred Miller
    December 5, 2011 at 7:18 pm
    It sounds like maybe the sequence settings might be different. Instead of making a new sequence just copy/paste (select sequence – command C – command V) and rename. Then start your new edit on the renamed sequence.
    FCP Studio 2
    Dual 3Gg Quad Core
    4Gg RAM
    KONA 3
    OS 10.5.8
  • Will Pigeon
    December 5, 2011 at 8:59 pm
    Thank you Fred!
    i wonder what settings are different…perhaps i will take the time to find out.
    But yes that’s cracked it so nice one.
