Activity Forums Adobe After Effects pulsing circles
  • pulsing circles
    Posted by Gone Fishing on July 24, 2009 at 11:41 pm
    I need to make a small circle that fades in while scaling up and then fade out and at the same time and before the first one disappears completely another one appears and i want that to be looping..i did that but I am not satisfied with the way I did it..can you help me with a better one which is based on expression or whatever.. i need this to help me in a map to show city location.
    David Johnson replied 17 years, 2 months ago 4 Members · 3 Replies
  • Scott Novasic
    July 24, 2009 at 11:47 pm
    Hi, try the plug-in Radio waves. It should do just what you are looking for. You will find it under plug ins than generate.
    hope that helps….
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Kevin Camp
    July 24, 2009 at 11:49 pm
    the radio waves effect may be the easiest way to do an effect similar to what you are describing….
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • David Johnson
    July 25, 2009 at 12:05 am
    I doubt you’d be asking if you had access to the Boris Continuum Complete third-party plugin set, but just in case you or anyone who does just hasn’t thought of using it for echo fx, the BCC Motion Trails plugin makes doing this very easy and also gives you lots of additional controls to do all kinds of variations of the same effect.
    And, if you wanted to get really fancy, you could also use any particle system plugin that can generate custom particles.
