Activity Forums Adobe After Effects Pulling element out of a map
  • Pulling element out of a map
    Posted by Bret Williams on May 20, 2010 at 4:24 pm
    Ok, not like a space zoom in. What I have is a map of the world and I have a few photos that I’d like to connect with areas on the map. I thought I’d use expressions or parenting to create that look of a photo that has a line from each corner extending down from the photo to a single point on the map. It’d be great if it could zoom out from the map. There any quick tuts on this before I reinvent the wheel?
    Bret Williams replied 16 years, 4 months ago 3 Members · 4 Replies
  • Bret Williams
    May 20, 2010 at 4:52 pm
    Ok, my non expression method… must be a better way. Create an inverted pyramid shape with 5 3D layers. 1 square and 4 traingles. The image is essentially the bottom of the pyramid. Parent the triangular sides to the bottom image. The triangles of course all come to a singluar point. Move the anchor point of the square image in z space to the point. Now, scale just the z parameter of the square image and it zooms forward or back, lengthening the trailing pyramid shape behind it. Maybe it’s 101 but I just haven’t had to do any zspace scaling that I can remember. Very useful.
    But there’s gotta be a better way that’s more accurate and automated.
  • Michael Szalapski
    May 20, 2010 at 5:16 pm
    You could use multiple instances of the Beam effect. And tie the end points to your photo’s corners.
    This page talks about how to do such a 2d layer effect point to a 3d position, basically use this expression.
    L = thisComp.layer("Null 1");
    L.toComp([0,0,0]);
    Where Null 1 is the name of the layer it’s tracking.
    You can either put a null in each corner of your pic with expressions (picwhip position and offset them to the corners in the expression + or – however many pixels)
    Or you could tie it directly to the picture layer itself and just + or – in the expression.
    There are actually tons of ways to do it. Perhaps others will have some alternatives.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Tudor “ted” jelescu
    May 20, 2010 at 5:53 pm
    I think you may be able to use Zaxwerks Serpentine on this. I know it tracks a layer, so if your layer is the picture, scale the Serpentine to match the pict size and play with opacity/transfer modes.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Bret Williams
    May 20, 2010 at 9:07 pm
    Thanks all. Going to follow up on those ideas. Always open for more!
