Activity Forums Avid Media Composer pulling edl from avid project file without an avid
  • pulling edl from avid project file without an avid
    Posted by Scott on June 29, 2005 at 1:55 pm
    I know automatic duck sells an ap that will translate Avid projects into FCP projects for $500, but is there anything cheaper out there?
    All I really need at this point is to print out the Avid EDL. I tried downloading Avid FreeDV and opening the avid project in that, but it would not open the project. I am not sure what version of Avid the other house worked in, but it certainly wasn’t FreeDV.
    We are working on a new project, and the folks here are looking at a window dub of a previously edited piece, picking out shots they want to use. I am simply trying to find out what reels and tc the original footage is on.
    Oliver Peters replied 21 years, 2 months ago 2 Members · 1 Reply
  • Oliver Peters
    June 29, 2005 at 2:06 pm
    If you have access to a standard Avid software disc, you can install EDL Manager onto most Macs or PCs. This doesn’t require a dongle and will let you open an Avid project and generate an EDL.
    Sincerely,
    Oliver
    Oliver Peters
    Post-Production & Interactive Media
    Orlando, FL
    http://www.oliverpeters.com
