Activity › Forums › Compression Techniques › Pulldown from 23.976
  • Pulldown from 23.976
    Posted by Rich Rubasch on September 8, 2013 at 5:18 pm
    I did some tests on a 23.976 sequence going to 29.97 for broadcast. Using Episode and their telecine framerate settings, no matter what I tried I got the CCCJJ cadence (clean frame, clean frame, clean frame, judder frame, judder frame). The judder frames were combined images with a ghosted image of the talent next to it.
    Playback was obviously juddery and had a rough look to it.
    For giggles I took the 23.976 ProRes HQ clip into QT Player and simply exported to 29.97. Now I got the CCCCDD cadence (clean frame, clean frame, clean frame, clean frame, new frame, duplicate frame).
    It played back perfectly and looked way better than the traditional 3/2 pulldown method with the judder frames. It is a :30 spot so there were no sync problems. Anyone else see this and is there any issue with using Apples pulldown (unconventional as it is) assuming I won’t have to remove the pulldown in the future?
    Rich Rubasch
    Tilt Media Inc.
    Video Production, Post, Studio Sound Stage
    Founder/President/Editor/Designer/Animator
    https://www.tiltmedia.com
    Rich Rubasch replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
