Activity › Forums › Adobe After Effects Expressions › pull effect index into layer ID string
  • pull effect index into layer ID string
    Posted by Steve Renard on June 1, 2011 at 4:01 pm
    Hi all – I am trying to link a bunch of separate lens flare effects (on an adjustment layer) to the 3D position of a bunch of null objects called “Camera Point 1”, “Camera Point 2”, etc. with several dozen points. I have the code to do the link, but it requires manually changing the layer indentity and I am wondering if there is a quick and easy way to pull the index of an effect into that string that identifies the layer. In my head it would read something like this:
    layer = thisComp.layer(“Camera Point >>effect index number<<"); layer.toComp([0,0,0]) The code I'm currently using is below. I imagine there's a quick way to do this - I just haven't been able to find it. Thanks for your help! Steve layer = thisComp.layer("Camera Point 1");
    Steve Renard replied 15 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 1, 2011 at 6:06 pm
    Try this:
    layer = thisComp.layer(“Camera Point ” + thisProperty.propertyGroup(1).propertyIndex);
    Dan
  • Steve Renard
    June 1, 2011 at 6:42 pm
    That’s perfect – thanks Dan!
