Activity Forums Square Box CatDV Publishing catalogues and file paths
  • Publishing catalogues and file paths
    Posted by Sava Pinney on December 6, 2011 at 7:12 am
    Two questions please, we are in the middle of a database set up.
    1. I am working with a client to set up their image database. Have customized a User Details panel and catalogued several folders of photos. Catalogues are saved to our network server, prior to the CatDV server being up.
    Now the CatDV server is up. I went in to Permissions, set several groups, roles and users up but oops published some of the tagged catalogues as Administrator, so they don’t belong to any group.
    Is this an issue? Should I unpublish them and republish from a group? (and how to do that?) I can see catalogues in the server tree as ‘Read only’.
    2. File path issue: I am working on one of our users computers (mac, user with system admin permissions) to test how its all going, and can open catalogues via ‘Browse’ catalogues option, navigating to the cats, ok but all the images are ‘offline’.
    I manage to relink after trying to open one image and following the prompts to load an equivalent path. This works well and relinks everything in all the catalogues – until I quit out and log back in and have to do it all over again.
    Is there a better way to do this?
    Thanks for your help, cheers
    Sava
    Sava Pinney replied 14 years, 8 months ago 2 Members · 2 Replies
  • Kevin Duggan
    December 6, 2011 at 11:15 am
    Hi Sava
    publishing as Administrator does no harm, though its not good practice :)- Hence the warning. You can change it with the bulk edit command. Catdv tracks who published each catalog so it can enforce permissions and access to catalogs .
    2. No what you did was fine but did you save the Preferences to the server so that they stick. Right click on the production group in the tree and SAVE GROUP SETTINGS (from memory )
    hope this helps
    Kevin Duggan
    CatDV/MME
  • Sava Pinney
    December 6, 2011 at 8:51 pm
    Ok thank you and thank you again! I love this software. That worked, it’s looking good.
    Cheers, Sava
