Activity › Forums › Corporate Video › Public speaking on a Canon 60D…what do I need?
  • Public speaking on a Canon 60D…what do I need?
    Posted by Danny Mulen on July 9, 2012 at 8:44 pm
    I’ve never done this before but there’s some compensation involved so I can’t miss out on the opportunity! Does anyone know the minimum equipment I need to record a 1 hour public speaking conference with just one Canon 60D? It’s only 1 speaker for 1 hour, and I understand these DSLRs stop recording every 12 minutes so this could be a huge problem!
    Also audio, if I ask the speaker to place a Zoom H4n nearby would that be sufficient?!
    Mark Suszko replied 14 years, 2 months ago 3 Members · 2 Replies
  • Tom Sefton
    July 10, 2012 at 11:02 am
    If you only have 1 DSLR camera for a public speaking job that lasts for 1 hour you need to hire something else.
    Either;
    at least 1 other 60D that you can set for a different shot, and then stagger the start so you can flit between both cameras to re-start and change cards. You will also need to purchase quite a few memory cards, or else you will have to transfer media onto a laptop whilst working and delete from the used cards meaning you have no backup. If you have to go down the DSLR route, I would recommend (at least)one other cameraman and camera for the job, and buy 4 more 32GB memory cards. You also need an external sound device for recording the speakers mic – you should be able to take a signal from the live mixing console and sync it in post.
    Or, hire a camera that is more suitable for the job – something with a large hard drive, a tape or something that can output a signal via HD-SDI that you can capture into your edit suite. You should also be aware of the issue of overheating – Canon DSLR’s get hot when used for video; we used one for B-Roll on an event once, and it overheated after 1hr’s use and needed cooling before we could use it again.
  • Mark Suszko
    July 10, 2012 at 2:52 pm
    Really, you need the appropriate tool for the job, as Tom points out, and the DSLR is not it.
    Rent something, even a DV camcorder set to shoot in wide-screen would work, and it will have a proper audio input as well.
    Don’t forget lighting, either.
