Activity Forums Adobe After Effects Psunami plugin
  • Psunami plugin
    Posted by Sam Rose on September 21, 2007 at 9:01 pm
    Hi
    I have the Psunami plug in. I am wanting to make a 3D ocean scene where it is at night and there is a storm and there are big waves. occasionaly there will be a flash of lightning and the ocean will be illulinated. How would I go about creating this. I know how to make the big waves but not so sure on the rain hitting the water and having a video of dark storm clouds as the sky?
    Sam Rose replied 18 years, 11 months ago 2 Members · 2 Replies
  • Lifetypo
    September 21, 2007 at 10:43 pm
    hey i got psnumai as well and i have to say it is the biggest resource hog plug in i ever used i mean to render out 5 seconds of a ocean took me well over a hour i was baffled .. but other then that , if i was you id use particles for the rain drops trapcode people website has a file for download with some good rain with drops hitting a colliosion point and breaking up . id start thier for the rain . the sky you could use fractal noise that should do the trick . or just take video of sky and put it in 3d space and move it above the ocean kinda flattend out .
    the easiest way to do lighnting is make a adjument layer . mask it on the sky and lil over the water and then keyframe the bright5ness to jump for one frame or so . u could also throw in the cc lighting effect in ae i think its cc not sure but its in thier somewhere
  • Sam Rose
    September 23, 2007 at 12:24 pm
    Hi
    Thanks very much for your help. I will try it.
