Activity › Forums › Apple Motion › PSD pixelation when brought into FCP as a motn clip
  • PSD pixelation when brought into FCP as a motn clip
    Posted by Jon Campbell on November 19, 2009 at 2:34 am
    I’m just getting started with motion and have run into a problem with a photoshop layer pixelating in the trip over from motion. I’ve made sure everything is Safe RT, high quality in my sequence and that motion files are rendered at high quality. This 45 sec screen capture video shows the problem. https://tinyurl.com/yela33o
    Any ideas?
    Mark Spencer replied 16 years, 9 months ago 3 Members · 2 Replies
  • Kellie Crowe
    December 23, 2009 at 1:52 am
    Jon,
    I’m having the exact same problem. I’m hoping you’ve either figured out a solution or someone has helped you remedy your problem. If you could post the “fix,” I would certainly be grateful.
    K. Crowe
  • Mark Spencer
    December 23, 2009 at 3:11 am
    You need to understand how the Canvas works in FCP – it is not showing you final quality. This may help:
    https://www.kenstone.net/fcp_homepage/motion_text_in_fcp_spencer.html
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
