Activity › Forums › Apple Final Cut Pro › .psd issues
  • .psd issues
    Posted by Korry Melton on February 29, 2012 at 5:15 pm
    I have a project I started back on FCPX 10.0.2 where I used some .PSD files in there for name supers. Now with the latest update, FCPx keeps crashing when I try to re-open it. I know the .psd files are the problem because I tried to import them into another project and it caused a crash as well. I actually had to merge the layers in Photoshop and re-export and it worked fine on another project.
    I really need to get back into this older project as I had done hours of editing, keying, etc. I tried to erase the source files from my drive and still it crashes.
    Andy Neil replied 14 years, 7 months ago 2 Members · 1 Reply
  • Andy Neil
    February 29, 2012 at 5:52 pm
    Go into the event for the project you can’t open ( using the finder). Select and delete the PSDs and then open FCPX. Then use the new relink feature to relink to the working PSDs.
    Andy
    https://www.timesavertutorials.com
