Activity › Forums › Apple Final Cut Pro Legacy › PSD in FCP5
PSD in FCP5
Posted by Randy Rohde on August 13, 2005 at 11:09 pmStill having no luck importing PSD to FCP and maintaining the layers. It is flat in FCP SO I have a question. Do I need to have Photoshop loaded on the G5 I am using FCP on?
Martti Ekstrand replied 21 years, 1 month ago 8 Members · 10 Replies -
David Battistella
August 13, 2005 at 11:32 pmAre you sure you are dealing with a layered PSD file. It should import as a sequence.
David
Tom Wolsky
August 14, 2005 at 1:21 amWas the PSD file made on a PC? The layer structure will not be maintained in FCP.
Sean Lander
August 14, 2005 at 6:54 am[Tom Wolsky] “Was the PSD file made on a PC? The layer structure will not be maintained in FCP.”
Really? I’ve never found this to be true in the past. Though I haven’t done it since FCP version 5. -
Tom Wolsky
August 14, 2005 at 10:57 amI’ve tested it in every version since v3, and it’s always been like that. Tried it last week with CS2 and 5.0.2 and it was the same.
Bouncing Account needs new email address
August 14, 2005 at 11:11 amHave you tried first opening (and maybe re-saving) those PC files in your Mac Photoshop?
Tom Wolsky
August 14, 2005 at 11:15 amThat works. The problem is for users, and I suspect the original questioner is one, who don’t have Photoshop or Photoshop Elements.
Tig Coates
August 14, 2005 at 1:05 pmthe GIMP can read/write PSD
It’s only 8bit I think but free and runs under X11Tig
Randy Rohde
August 14, 2005 at 2:27 pm1) What is GMIP? 2) I have no photoshop loaded on the G5 3) I create PSD with both Mac and PC 8 bit RGB LAYERED I load them in FCP and they are NOT LAYERED I take the same file and load it into photoshop (on another machine) and it IS LAYERED Sooo… They are not loading as sequences but as flat imageges My question is… Is anyone loading PSD or PNG layered files into a G5 FCP5 with no photoshop loaded on the same G5 that the FCP is loaded on?
Arnie Schlissel
August 15, 2005 at 3:33 pmBasically, Gimp is a free, open source knockoff of Photoshop. You do need to have X11 installed on your Mac to use it, though. You should have an X11 installer on your Tiger or Panther install disks.
Arnie
https://www.arniepix.com -
Martti Ekstrand
August 15, 2005 at 5:32 pmThere’s also GimpShop which is an attempt at mimicking PhotoShop’s lingo, layout and shortcuts as much as possible. Also needs X11 to run though
https://plasticbugs.com/index.php?p=241
cheers
