Activity Forums Adobe Premiere Pro PSD import to Premiere
  • PSD import to Premiere
    Posted by Ryan Santos on November 15, 2007 at 9:54 pm
    I’m having problems importing psd files to Premiere. Yesterday i can import without any problems. Now, I’m getting the message: unsupported file or corrupted file (can’t remember exactly), whenever I import. I tried opening the PSD file in my Photoshop, saving it with a different file name (but also as PSD since I need the alpha and layers) but still, I can’t import the file. What’s wrong? Thanks.
    Tim Kolb replied 18 years, 10 months ago 5 Members · 5 Replies
  • Dave Friend
    November 15, 2007 at 11:15 pm
    Make sure that your files are RGB. CYMK will not import.
    Dave
    Dave Friend
    Co-Host Discrete Edit*ors COW
  • Ryan Santos
    November 16, 2007 at 10:18 am
    Thanks Dave! I’ll try that right away!
  • Mike Velte
    November 16, 2007 at 11:38 am
    Depending on what versions of PS and AP you have, Photoshop can produce .psd files that Premiere cant import, If “Maximize Compatibility” is turned off in Photoshop.
  • Jon Barrie
    November 16, 2007 at 12:05 pm
    Just a quick note about using images in Premiere Pro, make sure you have the correct settings (pixel count) & aspect ratio to keep circles as circles and so on. Alpha channels are also kept in TIFF files and TGA’s. PSDs will come in as either sequences with the layers in them to use as a nest or as a flattened image. PSDs are also edit original compatible that allows you to open the original file in PS and make the changes to update in PPro.
  • Tim Kolb
    November 17, 2007 at 3:47 pm
    Is there anything you’ve added to the PSD that would have changed anything? Perhaps you can create copies of the file and delete layers until you see something change…or import each layer separately from separate documents…
    TimK,
    Director, Consultant
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
