PSD files blurry in playback and export
I have a sequence with PSD files and JPEGS and when the sequenced is paused the image is perfectly sharp and clear…then as soon as I play back the sequence the psd images are blurry and are even blurrier when i exported. I need to export in H264 but I also tried other codecs to see if it would make a difference and it didn’t.
I’m thinking the images aren’t the right size for the sequence but i’m not sure and also not sure how to fix that issue.Can anyone help with this?? Thank you!!
