Activity Forums Apple Final Cut Pro Psd files aren’t acting as expected
  • Psd files aren’t acting as expected
    Posted by Mark Morache on November 25, 2011 at 8:42 pm
    Did something change with 10.0.2?
    I was very happy with psd files. They came in flat, which is the way I like them. I could build any sort of transparency and it would import exactly as I wanted. I could change the psd, and it would update in FCX exactly as I wanted.
    Now I’m having trouble. Some of my psd files are importing as totally white frames.
    Some just import as the alpha channel, as a grayscale, with no other picture information.
    I may be doing something wrong, but as I look at a file that came in well with one that didn’t, I can’t honestly see what the difference is.
    Yes, I’m using rgb mode in 8 bit.
    Doing more tests…
    Looking at my PSD in the info window, in the settings view, there is a pull down for “alpha handling”.
    I should be able to use that to set the alpha to premultiply, straight or ignore/none.
    For some reason, I can change the setting, but it doesn’t always stick.
    Anyone have an idea of what I might be doing differently?
    It might be me doing something wrong in photoshop…
    This is weird: looking at my psd files in the finder, in thumbnail mode, they look normal. When I press the spacebar to see the preview mode, the normal looking psd is now all white.. What the heck?
    FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can’t stop thinking about her.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
    Rob Mackintosh replied 14 years, 10 months ago 2 Members · 2 Replies
  • Mark Morache
    November 29, 2011 at 7:24 am
    Hmmm… I think it was the “compatibility” issue.
    When I selected to maximize compatibility when I saved from Photoshop, the problem seemed to go away.
    Interesting.
    Mark Morache
    Avid/Xpri/FCP7/FCX
  • Rob Mackintosh
    November 30, 2011 at 9:47 am
    FCPX is reading the flattened preview that’s generated and embedded in the psd when you “maximize compatibility”.
    Reproduced this – created file from scratch in Photoshop, layered a couple of stills, adjusted opacity and added a text layer, saved two versions – on with max compatibility and one without.
    One with max compatibility is fine. The other version shows a thumbnail in the Finder but is all white in quick view, as it is in FCPX.
    When you drag a still from Aperture it does something similar – brings in the preview file at whatever res
    you have set in Aperture.
