Activity › Forums › Apple Motion › psd file problem – where did my alpha channel go?
  • psd file problem – where did my alpha channel go?
    Posted by Chris@horizon on January 16, 2007 at 6:45 pm
    I’ve a 2d graphic logo 720×486 saved as a photoshop psd file with a transparent background. I can load it into a FCP timeline and everything appears as it should, however when I import it into motion or livetype, it appears with a white background, the alpha channel is gone. Any ideas why it’s there on the fcp timeline but absent in motion and livetype? Thanks!
    Chris@horizon replied 19 years, 8 months ago 2 Members · 2 Replies
  • Doyle Rockwell
    January 17, 2007 at 6:29 am
    Heya,
    The alpha channel is still intact: Motion (and maybe LiveType) probably just aren’t guessing the proper interpretation. Once you’ve imported the PSD file into your project, select it and press Shift+F. This will show you the Media tab (in the Inspector) for that particular piece of media. From the Alpha Type popup menu, pick “Premultiplied-White”. Photoshop premultiplies alpha with white (which is weird, as most apps premult with black), so this should take care of your problem.
    Good luck with your project!
  • Chris@horizon
    January 18, 2007 at 4:06 pm
    Yes – Thank-you, that did it in Motion.
