Activity Forums Apple Final Cut Pro Legacy psd dimension question
  • psd dimension question
    Posted by Les Kaye on May 5, 2009 at 12:58 am
    This is a 720p project, and I want to make sure I’m not screwing things up.
    I have 2 sets of identical graphics from our artist – one set as jpgs, the other is layered psds. Both sets are 2667×1500. The pixel aspect of the jpgs is square, the psds are HD 960×720. The jpgs look fine in the timeline, the psds are horizontally stretched.
    I can fix the psds by changing the aspect ratio to square. Should I be requesting different settings or I am correct in what I’m doing?
    -Les Kaye
    http://www.leskaye.net
    David Bogie replied 17 years, 4 months ago 2 Members · 1 Reply
  • David Bogie
    May 5, 2009 at 7:28 pm
    what you’re doing will work until you rotate one of the images.
    suggest you carefully research the Photoshop for Video tutorials sprinkled all over the Net. Richard Harrington’s books and his work here on the cow should give you everythign you need to pass on to yoru PS artist who, by the way, should already have done all of this research on her own.
    bogiesan
