Activity Forums Apple Final Cut Pro Legacy psd de interlaced but still pixalised
  • psd de interlaced but still pixalised
    Posted by Nicolas on October 13, 2005 at 8:55 am
    hello,
    i have created a psd 720*576 to put on top right of my video ( actually it is a logo for a web tv) and de interlaced it but it still looks pixalised when i burn it on dvd. should i increase the resolution of the psd or what
    Espnetboy3 replied 20 years, 7 months ago 3 Members · 6 Replies
  • Walter Biscardi
    October 13, 2005 at 9:00 am
    You don’t de-interlace a graphic from photoshop for an FCP project. You de-interlace video stills going to photoshop.
    You probably don’t have your Motion filter setting turned to high quality. System Settings > Video Processing > Motion Filter, set this to High.
    Or you’re working in a DV timeline and the DV compression is affecting your graphic. the only way to have pristine graphics is to work in an Uncompressed timeline.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • Nicolas
    October 13, 2005 at 9:49 am
    ok i ve tried it but doesn t appear to make a difference.
    sould i start a new sequence and paste all the rush on it, because i heard it is not good to change the system setting while a project is open.
  • Walter Biscardi
    October 13, 2005 at 10:00 am
    [nicolas] “sould i start a new sequence and paste all the rush on it, because i heard it is not good to change the system setting while a project is open.”
    Never heard that one before.
    what type of sequence are you working with and how are you viewing the timeline?
  • Nicolas
    October 13, 2005 at 10:11 am
    i use
    timeline unlimited
    quality of lecture full
    i work in dv pal.
    my graphics appear pixelised when i press read it on FCP
    also you are telling me that i should not de interlaced my psd graphics when i export it?
  • Walter Biscardi
    October 13, 2005 at 10:17 am
    [nicolas] “timeline unlimited
    i work in dv pal.”
    DV is most likely your problem. it’s a compressed codec that does not do good things to graphics. The “timeline unlimited” is just your RT setting. DV is the codec.
    [nicolas] “my graphics appear pixelised when i press read it on FCP”
    Again, how are you viewing this? On a computer screen? FCP degrades image quality of the viewer and canvas. You have to view any project on an external monitor to see the true quality.
    [nicolas] “also you are telling me that i should not de interlaced my psd graphics when i export it?”
    There’s no reason to de-interlace a graphic for playback in a DV timeline.
  • Espnetboy3
    October 15, 2005 at 1:39 am
    biscardi, what do you mean working in an umcompressed timeline? with dv?
