Activity › Forums › Apple Final Cut Pro Legacy › PS3 H264 export?
  • PS3 H264 export?
    Posted by Brad Bussé on September 21, 2009 at 10:44 pm
    Anyone know how to export from FCP/Compressor a H.264 encoded file that the PS3 can read? I tried using QTPro to re-encode an H264 .mov to .mp4 using passthrough on the video and encoding the audio to AAC LC better setting, but the PS3 couldn’t read it. It can read a .mp4 exported from FCP, but even with the data rate at 62,000 kbit, there’s a ton of blocky compression artifacts. Alternative solutions like AVCHD or whatever would be appreciated too.
    Kevin Monahan replied 17 years ago 3 Members · 3 Replies
  • Tony Brittan
    September 22, 2009 at 12:32 am
    East enough to do in compressor…just play with the settings until you get it right. OR you can spend $30 and pick up the settings pack available at: compressorpack.com and use the custom ones provided! Worth the money to have over 100 presets that are awesome!
    Tony Brittan
    Apple Certified Pro – FCP
    islandshoreproductions.com
  • Brad Bussé
    September 22, 2009 at 12:36 am
    Thanks, I actually got it to work; you have to go to “Video Options” and uncheck Main in the restricted profiles.
  • Kevin Monahan
    September 22, 2009 at 8:29 pm
    Hey Guys,
    Does the PS3 playback AVCHD?
    Thanks.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
