Activity › Forums › Adobe Premiere Pro › PrPRo export vertical jitter
  • PrPRo export vertical jitter
    Posted by Alan Stephens on January 18, 2012 at 3:26 pm
    I am exporting my HDV from PrPro CS5.5 and I’m getting vertical jitter of the video to a h.254/mp4 file and also Apple TV 720, and other similar formats when I use 24p. If I change the frame rate to 29.97 it works fine.
    I have tried changing the field in the encoder to upper or lower and I still see it. the image jiggles up and down very slightly, like film in a projector.
    It is especially noticeable with graphics. have you seen this before?
    How do I correct this.
    Alan Stephens
    Alan Stephens replied 14 years, 4 months ago 3 Members · 6 Replies
  • Jeff Pulera
    January 18, 2012 at 4:23 pm
    Hi Alan,
    Any export for computer playback should be PROGRESSIVE, no fields, that is likely the issue you are seeing.
    Jeff Pulera
    Safe Harbor Computers
  • Alan Stephens
    January 18, 2012 at 5:13 pm
    In the field order I have also tried the default: None(Progressive)
    and still have the jitter at 24 fps.
    Alan Stephens
  • Alan Stephens
    January 18, 2012 at 6:41 pm
    I have updated media encoder to 5.5.1.12 and it seems to have solved the problem.
    Alan Stephens
  • Alan Stephens
    January 19, 2012 at 10:14 pm
    I retract that. No it didn’t solve the problem. I guess Adobe jsut doesn’t support24p.
    Alan Stephens
  • Frank Adamek
    May 4, 2012 at 2:05 am
    I’m Probably too late, but I ran into this thread when I had the same problem exporting h264 at 24fps.
    When you export, at the bottom there is the option to tick “Use Frame Blending” I checked that and it fixed everything.
  • Alan Stephens
    May 4, 2012 at 1:06 pm
    your not too late. I gave up on 24 fps and went with 30 instead.
    This is good to know!
    Alan Stephens
