Activity › Forums › Adobe Premiere Pro › PrPro CS6 – play doesn’t work?
Posted by Erik Lindahl on May 13, 2013 at 7:49 amHad an odd issue with PrPro CS6 this morning at my home studio. The app wouldn’t playback anything in either the source or canvas. Anyone know of this issue?
Tried pushing space, j / k / l, manually clicking with the mouse, turning mercury engine on and off. Nothing happens during attempt to playback but app doesn’t crash or anything. I can through VLC and QTX play media files from the same volume.
MacOSX 10.8.3, iMac 2012 pretty maxed out.
Erik Lindahl replied 13 years, 4 months ago 5 Members · 8 Replies -
Walter Biscardi
May 13, 2013 at 12:51 pmHave never seen this. Have you repaired disc permissions anytime recently? We try to do that at least every 2-3 weeks to keep the machines running smoothly.
Might want to start there.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative MediaFoul Water Fiery Serpent, an original documentary featuring Sigourney Weaver. US & European distribution by American Public Television
MTWD Entertainment – Developing original content for all media.
“This American Land” – our new PBS Series.
“Science Nation” – Three years and counting of Science for the People. -
Kris Merkel
May 13, 2013 at 1:18 pmI have seen this happen only once and it was a result of a bad PrPro install. If rebooting and then repairing your permissions does not help, you can try to troubleshoot by opening another project to see if the problem persists.
If it does then you can troubleshoot further to see if it works in the Root user or you could just uninstall the app and then re-install following the directions very carefully. More than likely though it is a conflict with an output or other connected device, card, monitor drive ect. and Walters first recommendation will fix it.
“Think of everything in terms of building capacity.”
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W -
Erik Lindahl
May 13, 2013 at 1:31 pmI’ll give these suggestions a try when I get back home. Very odd issue.
Tim Kolb
May 13, 2013 at 3:18 pmAnother thing you may want to check is display card drivers. It’s amazing how much they can affect fundamental playback functionality when they’ve gone wonky or something has been installed that has created a conflict.
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
Erik Lindahl
May 13, 2013 at 3:22 pmWell I’m running OSX 10.8.3 on an iMac 27″ 2012 w nVidia 680MX so I don’t think I can affect the display driver a whole lot.
Erik Lindahl
May 13, 2013 at 7:23 pmI tried repairing permissions, creating a new project, deleting render files with no luck. Then I turned on full screen playback on my secondary monitor and wha-la – it works again. Very odd!
Bret Williams
May 14, 2013 at 4:10 amThat card isn’t actually supported by the mercury engine, right? So you had to hack the file to get cuda or open CL?
I had the same problem with opencl on my mid-2011 iMac. Things would just stop working. No playback. Weird. So I quit using the hack.
But I’m on the same machine as you now, and I have the hack to get cuda, and all seems fine.
