Activity › Forums › Adobe Premiere Pro › PrPro CS5.5 gives me the blues
Posted by Alan Stephens on February 10, 2012 at 8:38 pmIn the process of solving my other problem I got the blues for some reason. My exports to Pro Res are BLUE! My old projects will export ok unless I reimport the same HDV footage and export to the Queue. If I do Export it seems to be ok.Or use another file type works in Queue. If I convert the file directly thru Media Encoder it works ok.
What is up with this! Anyone run into this?
vr 5.5.1.12Alan Stephens
Todd Kopriva replied 14 years, 5 months ago 3 Members · 10 Replies -
Todd Kopriva
February 11, 2012 at 6:10 pmAre you using third-party hardware (e.g., AJA, Matrox)?
We’ve seen this problem before with out-of-date AJA codecs.
Also, I notice that you’re using Premiere Pro 5.5.1, not 5.5.2. I recommend choosing Help > Updates and installing the latest bug-fix update.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Alan Stephens
February 11, 2012 at 10:02 pmI checked and I have already updated to 5.5.2
I have no 3rd party hardware.
Running MacBook Pro with LionAlan Stephens
Todd Kopriva
February 13, 2012 at 6:27 pmThat’s odd.
Here’s a document that I wrote up about a related issue:
https://kb2.adobe.com/cps/915/cpsid_91507.html… but that seems to be the reverse of the case that you’re seeing.
Do you mean that this just happens when you’re using specific HDV source footage? Or are you referring to the output type—i.e., that this happens only when exporting to ProRes? (If so, which variant of ProRes?)
Alan Stephens
February 13, 2012 at 9:57 pmSo far I have only seen it with ProRes 1080P or 720P.
I seems to be intermittent, as I could export to queue from a previous project with out a problem, but when I put in the newer HDV.mov and
tried it again the old project files had the same problem, where as they didn’t previously. The crop tool seem to correct the blue problem.
It was exporting in full color so stopped the encode to try a different size output and Media Encoder crashed. I had to reboot the computer to get it to clear. I notice when exporting to ProRes when I reopent the Queue to make adjustments that there is no preview of the footage.
Is that normal? A Pro Res thing?Alan Stephens
Todd Kopriva
February 13, 2012 at 9:58 pm> there is no preview of the footage
You must be using Mac OSX v10.7.3. That Lion update introduced a bug that broke previews in Adobe Media Encoder.
Alan Stephens
February 13, 2012 at 11:11 pmyes indeed. 10.7.3. That’s probably why it just showed up recently.
Who gets to fix that, Apple or Adobe?Alan Stephens
Todd Kopriva
February 13, 2012 at 11:16 pm> Who gets to fix that, Apple or Adobe?
It appears to be an Apple bug, but I’m not 100% sure where the fix would come from. We’re working with Apple on it.
Fil Baumanis
March 30, 2012 at 12:27 pmany update on this? it’s a difficult problem to contend with when cutting and adding cue points…
Alan Stephens
March 30, 2012 at 2:56 pmyes there is a work around, some one sent me an Adobe link to a pdf.
but I guess that didn’t make it to this thread.here is the quick fix from the pdf, until they fix it.
Solution
In Adobe Premiere Pro, apply the Crop effect to each clip that has the blue color cast. Leave the properties of the Crop effect at their default values, so that the effect does nothing to the image.
If you have multiple clips with this problem, you can create a new transparent video clip (https://www.adobe.comhttps://help.adobe.com/en_US/premierepro/cs/using/WS363B6AD6-AC91-4f2a- 83F1-7FB1704A9143.html) . Put it in the topmost video track, and apply the Crop effect to the transparent video clip.Alan Stephens
Todd Kopriva
March 30, 2012 at 3:04 pmHere’s the solution that Alan is referring to:
https://helpx.adobe.com/premiere-pro/kb/movies-have-blue-cast-exported.html———————————————————————————————————
product manager, professional video software
