Activity Forums Adobe Premiere Pro PrP performance on Mac vs. PC
  • PrP performance on Mac vs. PC
    Posted by Tom Daigon on July 20, 2011 at 1:01 pm
    I love much of what PrP and AE offer thru the dynamic link. I am concerned that performance on my Mac Pro 3.1 / 24 gigs rams / Areca controlled 8tb raid array / leaves a lot to be desired in terms of just simple playback of 1080 Prores clips (for example). In the source window I I can scan by dragging the little playhead control through through the clip and it plays very smoothly (all frames played). When I try the same process in the record window it jumps about 10 + or – frames as I drag. . Full resolution playback or variations make no difference. This occurs on both the AJA and Adobe sequence configurations. CS 5.5 seems to function better on a PC then a MAC and that could cause me to try Avid for better performance..
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Alex Hawkins replied 15 years, 1 month ago 11 Members · 27 Replies
  • 27 Replies
  • Jason Jenkins
    July 20, 2011 at 1:12 pm
    I know you’ve mentioned this before, Tom, but I can’t remember; do you have a GPU that is giving you CUDA acceleration? If not, I wonder if that would make the difference?
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
  • Tom Daigon
    July 20, 2011 at 1:23 pm
    Hi Jason. I use Kona 3 since some clients still have material on tapes, as well as HD-SDI to a engineering monitor for QC and client viewing. In the Adobe literature Ive read. it says the process of playback involves decoding, which CUDA does not do.That is a function of the CPU if I understand correctly. A moot point due to my Kona workflow.
    Tom Daigon
  • David Cherniack
    July 20, 2011 at 1:25 pm
    Jason’s question is relevant in that if you have any effects applied to the timeline clips jogging or scanning the timeline is going to be jerky. If you have a CUDA card with CUDA effects applied it’s going to be much smoother.
    David
    AllinOneFilms.com
  • David Cherniack
    July 20, 2011 at 1:28 pm
    That is correct. And iff the Adobe timeline demonstrates the same jerkiness, then the Kona drivers are not to blame.
    David
    AllinOneFilms.com
  • Tom Daigon
    July 20, 2011 at 1:29 pm
    No effects on the timeline , just clips. I guess my workflow might necessitate checking out Avid since not using the Kona is not an option. Thanks for the info David.
    Tom Daigon
  • David Cherniack
    July 20, 2011 at 1:34 pm
    [Tom Daigon] “No effects on the timeline , just clips. I guess my workflow might necessitate checking out Avid since not using the Kona is not an option. Thanks for the info David.”
    Like I said in the other post the issue is probably not the Kona drivers if it behaves the same way in Adobe timelines.
    One thing to try: In Preference:Viewers switch from the AJA viewer to the Adobe viewer.
    Otherwise it’s almost certainly an issue with Prores in PrPro or QT issues. Todd may be able to tell you definitively about this.
    David
    AllinOneFilms.com
  • Tom Daigon
    July 20, 2011 at 1:38 pm
    I have explored the preference switch between Adobe and AJA with no affect. Actually I was using Prores as one example I experience this same ” skipping” playback issue in the Record Monitor with all clips/formats/codecs.
    Tom Daigon
  • David Cherniack
    July 20, 2011 at 1:46 pm
    I just want to be clear on whether this happens with jogging the playhead or playing the timeline. I’ve assumed that it’s only with jogging. If that’s the case, does it also happen when you drag the timeline playhead?
    David
    AllinOneFilms.com
  • Tom Daigon
    July 20, 2011 at 1:48 pm
    Tom Daigon
  • David Cherniack
    July 20, 2011 at 1:52 pm
    Does it also happen when you drag the timeline playhead when you’re zoomed in?
    Your slider resolution in the program panel may be too low.
    David
    AllinOneFilms.com
Page 1 of 3
