Activity › Forums › Adobe Premiere Pro › PrP CS6 and CoreMelt
Posted by Wendell Davis on July 9, 2012 at 3:00 pmAnyone using Lock and Load? I get and error message when trying to stabilize – any thoughts?
WendellWendell Davis replied 14 years, 2 months ago 2 Members · 2 Replies -
Ann Bens
July 9, 2012 at 3:40 pmDoes it give the same error with the plugin applied?
Or try nesting first then stabilize.———————————————–
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Wendell Davis
July 9, 2012 at 7:11 pmThanks Ann.
Just a simple stabilize of one track. The challenge is that it is not the same size as the sequence… so that is my problem. My work around was to take the footage make its own sequence, stabilize it, then export it and bring it in pre-stabilized. Works OK but extra steps.
I get a lot of footage from “wherever” sources and it cause some challenges sometimes. Coremelt Lock and Load does a better job than Premiere’s stabilizer.
Appreciate your reply.
Wendell
