Activity › Forums › Apple Final Cut Pro › Proxy Workflow
Proxy Workflow
Posted by Jon Smitherton on October 4, 2011 at 10:17 pmHi
I have just shot my first project that I intend to edit in FCPX.
I have imported my DSLR files – 1080p25 PAL and converted these into proxy media as I felt the system was needing to render too much with the H264 files on my new Macbook Pro (more RAM perhaps? – only have 4 gig).I plan to deliver PAL SD 1024×576 – as this is all I’d need an I can get extra accommodation out of the larger source frame size (can turn a wide into a close-up etc).
Am I better editing into a SD PAL timeline or edit HD then place into a SD timeline so I get more realtime capabilities in the ‘offline’?
I find that when I drop a proxy clip into a SD timeline the scale properties say 100% instead of giving me the correct percentage of a HD clip in a SD timeline.
Also after I finish my SD edit how do I change the timeline to High resolution? Surely this works on the media used not the complete source media.
Many Thanks,
JonJason Jenkins replied 14 years, 8 months ago 5 Members · 10 Replies -
T. Payton
October 4, 2011 at 11:42 pmActually FCP X has all this worked out for you already. Just import your h264 footage, and then choose “create proxy” while you are importing or select all your footage and right click and choose “transcode” then choose “create proxy”. This will take a little while to make proxy version of your clips.
Then while you edit, in preferences under playback choose to play “proxy media”. When you are ready for your final hires version, just choose “original media”.
No scaling, not nothing. Just change the preference.
T. Payton
OneCreative, Albuquerque -
T. Payton
October 4, 2011 at 11:48 pmOh forgot to mention when you create your project, or timeline, just choose your delivery size and format there in your case PAL SD.
As far as letting you reframe without resampling the footage, just do a little math and you can figure out the max percentage of zoom before it starts resampling. I’m guessing it is going to be just under 200%.
T. Payton
Jon Smitherton
October 4, 2011 at 11:50 pmHi Tim
Thanks, have done this…however I am using HD in a SD timeline (specifically for resizing and cropping features) and at the moment says 100% for a HD clip in a SD timeline (in FCP 7 it would say 53.3%). Wondering if this has something to do with the proxy size – 960×540 vs 1920×1080.
Cheers,
Jon -
Jason Jenkins
October 5, 2011 at 12:03 am[jon smitherton] ”
Thanks, have done this…however I am using HD in a SD timeline (specifically for resizing and cropping features) and at the moment says 100% for a HD clip in a SD timeline (in FCP 7 it would say 53.3%). Wondering if this has something to do with the proxy size – 960×540 vs 1920×1080.”It says 100% because the Spatial Conform setting defaults to “Fit”. You can still scale the footage, you just have to re-figure the percentage. If you want the clips to act like they do in FCP7, you need select them in the Event Browser and in the Inspector change the Spatial Conform to “None”. Then put them in the timeline.
Jason Jenkins
Flowmotion Media
Video production… with style! -
Michael Reiersgaard
October 5, 2011 at 5:22 amJust wanted to chime in at the incredible difference I noticed going for 4GB to 12GB of RAM for Final Cut Pro X. It’s such an inexpensive upgrade that there’s almost no reason to edit with 4GB of RAM.
Dave Gage
October 5, 2011 at 7:36 pm[Jason Jenkins] “It says 100% because the Spatial Conform setting defaults to “Fit”. You can still scale the footage, you just have to re-figure the percentage. If you want the clips to act like they do in FCP7, you need select them in the Event Browser and in the Inspector change the Spatial Conform to “None”. Then put them in the timeline.”
Jason,
So, based on our previous posts in this thread-
https://forums.creativecow.net/thread/344/4357…if working with 1080p files on a 720p timeline with the intention of being able to zoom and crop in, I should also change the Spatial Conform settings to “None” before I begin adding files to the Project timeline. Since you did say in that post, “In FCPX, I set the Spatial Conform on my footage from the default of “Fit” to “None”, before I drop it in the timeline.“)
Aside from doing what you explained, does changing the setting from “Fit” to “None” have any other affects on the project I should know about? (I’m just now starting to understand the big picture here and the terminology involved.)
Dave -
Jason Jenkins
October 5, 2011 at 11:09 pm[Dave Gage] “…if working with 1080p files on a 720p timeline with the intention of being able to zoom and crop in, I should also change the Spatial Conform settings to “None” before I begin adding files to the Project timeline.”
If you set the Spatial Conform to “None”, then the clips will show up in the timeline at 100% scale and will appear cropped. To see the entire image, you’ll set the scale to 66.7%. Scaling anywhere between 66.7% and 100% is possible with no resampling.
If you leave the Spatial Conform setting to it’s default of “Fit”, the clips will show up in the timeline at 100% scale but will in fact be scaled down to fit the entire image in the frame. In this scenario, you can scale your video up to 133.3% to achieve the same view that you had at 100% in the “None” scenario. Scaling anywhere between 100% and 133.3% is possible with no resampling.
So, the same thing is happening behind the scenes in either scenario. The only difference is what the Scale parameter says in the inspector.
Jump in and play around, Dave! That’s the best way to figure stuff out.
Jason Jenkins
Flowmotion Media
Jason Jenkins
January 5, 2012 at 9:30 am[Jason Jenkins] “If you set the Spatial Conform to “None”, then the clips will show up in the timeline at 100% scale and will appear cropped. To see the entire image, you’ll set the scale to 66.7%. Scaling anywhere between 66.7% and 100% is possible with no resampling.
So, the same thing is happening behind the scenes in either scenario. The only difference is what the Scale parameter says in the inspector.”
Correction: When editing 1080p in a 720p timeline where the footage is set to the Spatial Conform setting “Fit”, the footage actually needs to be scaled to 150% (not 133.3%) in the timeline to be sized up all the way and see its full resolution. My math was wrong in the previous post. In the Spatial Conform “None” scenario, a scale setting of 100% represents all of the 1920×1080 resolution and scaling to 2/3’s of that (66.7%) will fit it into the 1280×720 frame. In the Spatial Conform “Fit” scenario, a scale setting of 100% represents 2/3’s of the 1920×1080 resolution and scaling up to 150% represents all of the 1920×1080 resolution.
Jason Jenkins
Flowmotion Media
Video production… with style!Check out my Mormon.org profile.
