Activity Forums Adobe Premiere Pro Proxy voodoo, what am I missing?
  • Proxy voodoo, what am I missing?
    Posted by Aaron Rosapepe on July 16, 2020 at 2:20 am
    I am in the process of setting up post workflow for an eight episode series. While honing in the proxy workflow I found that the “Prores Low Resolution Proxy” found within Premiere gives me the resolution I need with the small files I am aiming for.
    Here’s where the voodoo comes in. These files are “1024×540” which shouldn’t be the right aspect ratio but look fine when utilizing the proxy workflow within Premiere. All good and fine but I need more flexibility when defining the audio portion of this proxy so I head on over to Media Encoder. I make a preset with the exact specs as the one inside of Premiere but when I use this new ingest preset, it kicks out a proxy with black bars on the side due to the incorrect aspect ratio.
    To further add insult to injury, if I try and make the correct ratio of “1024×576” I end up with a proxy that is the correct aspect ratio but it is now over twice the amount of disk space as the “1024×540” version. What kind of sorcery is this?!
    (I’ve included screen shots of the Premiere preset and the one that comes out of Media Encoder. Both have the same aspect ratio and settings)
    Herb Sevush replied 6 years, 2 months ago 3 Members · 5 Replies
  • Chris Wright
    July 16, 2020 at 4:13 am
    proxies have to be multiples evenly divisible and same aspect ratio and pixel aspect ratio. There’s two kinds of ratios.
  • Aaron Rosapepe
    July 16, 2020 at 10:49 am
    Hi Chris,
    What I am trying to figure out is why the “Prores low resolution proxy” preset within Premiere kicks out a 1024×540 file that still looks correct in a 1920×1080 timeline when proxy mode is engaged but the same specs done within media encoder, kick out a file with black bars on the side.
  • Herb Sevush
    July 16, 2020 at 11:54 am
    “why the “Prores low resolution proxy” preset within Premiere kicks out a 1024×540 file that still looks correct in a 1920×1080 timeline when proxy mode is engaged but the same specs done within media encoder, kick out a file with black bars on the side.”
    Because the pixel aspect ratio is different. you have to dig deeper into the Video setting to change the pixel aspect ratio.
    “if I try and make the correct ratio of “1024×576” I end up with a proxy that is the correct aspect ratio but it is now over twice the amount of disk space as the “1024×540″ version. What kind of sorcery is this?!”
    When making your own Proxy settings lower the quality of the file (in ProRes choose Proxy, in .h264 lower the bit rate.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
  • Aaron Rosapepe
    July 16, 2020 at 11:59 am
    Thanks Herb. We are sticking with prores proxy QT mov for this project however. We will probably go with 1280×720 even though the file sizes will be bigger.
    Mainly just trying to solve the riddle of how Premiere gets the 1024×540 to look right when doing it all in Premiere. The preset is located here if anyone else wants to try it out.
  • Herb Sevush
    July 16, 2020 at 12:02 pm
    The pixel aspect ratio of their standard proxy setup is not square, not set at 1:1.
    Don’t know why they do it that way, I had the same surprise when I first started using the proxy workflow.
    Herb Sevush
    Zebra Productions
