Activity › Forums › Maxon Cinema 4D › proxy texture maps
proxy texture maps
Posted by Alan Lacey on October 20, 2005 at 6:37 pmI need to create some small strutures accuately aligned to a mapped hires texture. Is it possible to up the displayed proxy texture in the viewport? having to keep re-rendering the area where I’m working is a real pain.
Also what about a ‘repeat the last render’ command like the one Max has, does that exist anywhere in C4D?
Thanks again for help.
Alan
Moka-studio replied 20 years, 10 months ago 3 Members · 6 Replies -
Todd Groves
October 21, 2005 at 1:14 amSelect the texture tag in the Object Manager. Go to the Illumination tab under the texture attributes and choose the 1024×1024 setting under the Texture Preview Size dropdown list.
As far as a “repeat last render” choice, as long as you don’t change the settings in the Render Settings dialog there’s no need for such a script. Simply re-render the scene. Or, if you have R9.5 you can save the Render Settings as a preset, enabling you to choose the preset from a drop down listing.
Moka-studio
October 21, 2005 at 10:22 amHave a look at the 10 comm plugin from Paul Everett, it features a Show Last Render option, as well as a window in which you can load 2 renderings to compare differences.
I remember that Max has an option that re-renders only modified parts of the image if the rest of the view remains the same, right? That would be nice.
jean-pierre,
Alan Lacey
October 21, 2005 at 4:35 pmThanks Todd, in fact I found it about five minutes after posting. Pook!
Yes jean-pierre, it’s the repeat last partial render that I was after. I’ll check out the plugin, thanks
Alan
Todd Groves
October 21, 2005 at 4:40 pmAhh. I see what the idea is. Yes, being able to re-render a scene where it just calculates the altered areas would be nice.
It also would be nice if C4D could have a render region that stayed active like in XSI, and each time you made a change in settings or camera angle it re-rendered the region. Or even like Maya’s, where you render to a viewer and it re-renders with each change as well.
Alan Lacey
October 22, 2005 at 8:30 pmDo you think there’s any chance of being able to do this with a script?
Alan
Moka-studio
October 24, 2005 at 1:50 pmSend a request to Maxon, they are quite responsive to user requests.
jean-pierre,
