Activity Forums VEGAS Pro Proxy Stream issue
  • Proxy Stream issue
    Posted by Patrick Perry on September 8, 2009 at 6:42 am
    I recently downloaded Proxy Stream with the hopes of using it to help with proxy editing. However, every time I try to customize the convert settings, I get a rather long error message that begins: “System.Security.SecurityException: The source was not found, but some or all event logs could not be searched. Inaccessible logs: Security.” It goes on much further, but maybe it’ll be of some help. Anyone experienced this before? I’m editing on Sony Vegas Pro 9, FYI. Thanks for any help you can give.
    Chris Tewfik replied 15 years, 10 months ago 4 Members · 5 Replies
  • Gilles Pialat
    September 9, 2009 at 11:26 am
    Sony made some changes between the VP8 and VP9 script API.
    So my script is not fully compatible with VP9 (and will not be).
    However, you can create your custom template in Vegas, it will be available in ProxyStream.
    Gilles
  • John Rofrano
    September 9, 2009 at 1:41 pm
    You might want to look at purchasing the original Vegas proxy editing solution VASST GearShift. It is fully supported and compatible with Vegas Pro 9.0 both 32 and 64-bit. You can make your own conversion templates with GearShift as well. It’s documented in the User’s Guide.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Patrick Perry
    September 10, 2009 at 2:59 am
    Consider the issue fixed.
    Gilles, I was hoping to get a response from you and your advice worked perfectly. It’s very nice to see smooth video playing back in the preview window. Thanks again.
    John, I will definitely keep Gearshift in mind for the future. Thanks for the info!
  • Chris Tewfik
    October 27, 2010 at 8:17 am
    I don\’t get it… I\’m having the exact same problem in Vegas Pro 9
  • Chris Tewfik
    October 27, 2010 at 8:24 am
    I don’t know what I’m doing wrong but I get the long error message too
