Activity Forums Adobe After Effects Proxy sizing question
  • Proxy sizing question
    Posted by Julius Karli on January 12, 2017 at 3:23 pm
    Hello.
    I have a question on proxies in AE. My Footage is 4K (Sony FS7) and I made 720p Prores Proxy proxies for faster working in AE.
    Now: If i relink from the 720p proxies to the 4K footage the sizing in my AE composition is changing.
    Is it possible to relink the to the 4K footage without changing the sizing?
    Thank you for your help.
    Ju
    Julius Karli replied 9 years, 8 months ago 2 Members · 4 Replies
  • Walter Soyka
    January 12, 2017 at 4:29 pm
    If you use Ae’s proxy feature [link] (instead of just replacing footage), Ae will understand and track the correct original sizing.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Julius Karli
    January 12, 2017 at 4:49 pm
    Hey Walter.
    I totally forgot about this feature. This is nice!
    Just to make sure:
    I worked with the proxies in AE and want to relink to the 4K full quality files. So I just “set proxy” and link to the 4K full quality files and have to render with the “new 4K full quality proxies” …?
  • Walter Soyka
    January 12, 2017 at 5:00 pm
    [julius karli] “I worked with the proxies in AE and want to relink to the 4K full quality files. So I just “set proxy” and link to the 4K full quality files and have to render with the “new 4K full quality proxies” …?”
    I don’t think this will work the way you want. Ae thinks the files are supposed to be 720p and will scale the 4K full-quality “proxies” down accordingly. You should have started with the full resolution to use the proxy feature.
    Perhaps you can use the Scale Composition script, then reconnect your footage, then re-adjust the scale.
    Walter Soyka
  • Julius Karli
    January 13, 2017 at 5:38 pm
    Thanks for helping me.
    I ended up in starting again with the 4K files and set proxies …
    Best, Ju
