Activity › Forums › Apple Final Cut Pro Legacy › “proxy render”
“proxy render”
Posted by Coulter Mitchell on July 14, 2010 at 7:56 pmAll of my clip settings in my bin (720*480 29.97 fps) are the same as my timeline settings but when I drop a clip in the timeline i get a yellow “proxy render” line what do i have to do to not have to render every clip I drop in the time line
ThanksBen Finkel replied 15 years, 7 months ago 4 Members · 6 Replies -
Shane Ross
July 14, 2010 at 8:20 pmYou failed to mention one very important thing. What CODEC is your footage, and what codec is your sequence set to?
Shane
Read my blog, Little Frog in High Def -
Shane Ross
July 14, 2010 at 10:43 pmAny filters on that? The only time I see YELLOW is when I add the SMOOTHCAM…
Shane
Nick Meyers
July 15, 2010 at 3:32 ami think i’ve gotten the yellow “Proxy” render line if i have the canvas set to white or checkerboard bg.
but that would also imply that there is some scaling or motion effect being applied to your clip as you add it to the timeline.
nick
Nick Meyers
July 15, 2010 at 3:41 am“caling or motion effect being applied to your clip as you add it to the timeline. ”
which could imply that your sequence settings do NOT match your clip settings.
nick
