Activity Forums Adobe After Effects Proxy Question
  • Proxy Question
    Posted by Kevin Dennis on February 16, 2006 at 4:03 pm
    I’m rendering footage that I need to bring back into my project to be used in another composition.
    I want to setup the comp that will use this “Pre-Rendered” footage and add that to the Render Que as well.
    In other words how do I setup proxies for files that don’t exist yet.
    I’m not doing the hi-res/lo-res swap. I using a still image as a placeholder in a comp till the footage is rendered then I want the still to be replaced with the rendered video file and then that comp rendered.
    Hopefully all overnight in one Que.
    I hope that wasn’t too confusing…
    Kevin
    Kevin Dennis replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
