Activity Forums Adobe After Effects Proxy problems if using psd layers
  • Proxy problems if using psd layers
    Posted by Peter on August 28, 2006 at 1:30 pm
    hi there,
    i got the following problem with settings my proxys:
    I got my original big jpg file and i save this smaller as a psd file.
    Then i set the proxy in afer effects. works fine. The quality is less but beside that it shows the same.(size….)
    but:
    if i work with this file before in psd, and if i save that one in different layers the same procedure is not working. I got the file ,after setting the proxy , shown more big, even if the proxy ,of course, is smaller.???
    Any suggestions?
    thanx
    peter
    Peter replied 20 years ago 2 Members · 2 Replies
  • Mylenium
    August 28, 2006 at 6:54 pm
    If you are changing the relative layer positions/ dimensions, it affects the pixel sizes stored in the PSD file. You need to crop your images to the actual canvas size to maintain the original dimensions.
    Mylenium
    [Pour Myl
  • Peter
    August 29, 2006 at 9:41 am
    Hi Mylenium
    sorry but i didn’t geht the point….I mean i cut my original foto in layers and then i store it as a big and a small file…So i thought i did not change the “relative layer positons” . What do you mean by saying “crop image to actual canvas size”? You speak about doing that in ae? D0 you work like this, psd in layers , setting proxys?
    thanx for your support
